Shaganova pila
+9
Jelena
Shagan
13 posters
Shaganova pila
Evo kao što obečah da vam predstavim svoj projekt na kojem radim več dvije godine (preko tjedna sam u ZG u školi tak da ne stignem radit bas previše) auto je 76' godište kupljen je za nekih 180€. Pošto na njemu radim već dosta dugo i polako dati ću vam ubrzan prebled radova.
![Shaganova pila Cimg1753jf2.th](https://2img.net/r/ihimizer/img513/4116/cimg1753jf2.th.jpg)
![Shaganova pila Cimg1755sm3.th](https://2img.net/r/ihimizer/img171/3136/cimg1755sm3.th.jpg)
![Shaganova pila Cimg1757lq5.th](https://2img.net/r/ihimizer/img171/6656/cimg1757lq5.th.jpg)
![Shaganova pila Cimg1760jh3.th](https://2img.net/r/ihimizer/img233/4081/cimg1760jh3.th.jpg)
![Shaganova pila Cimg1759fz9.th](https://2img.net/r/ihimizer/img233/7580/cimg1759fz9.th.jpg)
![Shaganova pila Cimg1762gw0.th](https://2img.net/r/ihimizer/img261/7311/cimg1762gw0.th.jpg)
![Shaganova pila Cimg1763ca6.th](https://2img.net/r/ihimizer/img171/9386/cimg1763ca6.th.jpg)
![Shaganova pila Cimg1764xk2.th](https://2img.net/r/ihimizer/img233/3340/cimg1764xk2.th.jpg)
![Shaganova pila Cimg1765zc6.th](https://2img.net/r/ihimizer/img171/3725/cimg1765zc6.th.jpg)
![Shaganova pila Cimg1761mv8.th](https://2img.net/r/ihimizer/img233/2458/cimg1761mv8.th.jpg)
![Shaganova pila Thpix](https://2img.net/r/ihimizer/images/thpix.gif)
evo ekipa uživajte u slikama. Ako koga kaj zanima neka pita jer ja volim pratit forume ali sam ljen do boli za naslikavanje stalno i piskaranje. Ja sam ono tiha voda brege dere stil.
![Shaganova pila Dscf00015rt.th](https://2img.net/r/ihimizer/img416/3713/dscf00015rt.th.jpg)
![Shaganova pila Dscf00023ou.th](https://2img.net/r/ihimizer/img62/8049/dscf00023ou.th.jpg)
![Shaganova pila Dscf00031jw.th](https://2img.net/r/ihimizer/img391/4369/dscf00031jw.th.jpg)
![Shaganova pila Dscf00040sh.th](https://2img.net/r/ihimizer/img391/672/dscf00040sh.th.jpg)
![Shaganova pila Dscf0002mx1.th](https://2img.net/r/ihimizer/img359/24/dscf0002mx1.th.jpg)
![Shaganova pila Dscf0003me6.th](https://2img.net/r/ihimizer/img301/2871/dscf0003me6.th.jpg)
![Shaganova pila Dscf0007xy2.th](https://2img.net/r/ihimizer/img118/2466/dscf0007xy2.th.jpg)
![Shaganova pila Cimg0073ns0.th](https://2img.net/r/ihimizer/img353/3607/cimg0073ns0.th.jpg)
![Shaganova pila Cimg0074md1.th](https://2img.net/r/ihimizer/img520/5087/cimg0074md1.th.jpg)
![Shaganova pila Cimg0075cm9.th](https://2img.net/r/ihimizer/img166/7521/cimg0075cm9.th.jpg)
![Shaganova pila Cimg0076zj4.th](https://2img.net/r/ihimizer/img376/1949/cimg0076zj4.th.jpg)
![Shaganova pila Cimg0078tp6.th](https://2img.net/r/ihimizer/img376/4156/cimg0078tp6.th.jpg)
![Shaganova pila Dscf0005xj8.th](https://2img.net/r/ihimizer/img301/6068/dscf0005xj8.th.jpg)
![Shaganova pila Cimg1198ie7.th](https://2img.net/r/ihimizer/img516/8431/cimg1198ie7.th.jpg)
![Shaganova pila Cimg1246pl5.th](https://2img.net/r/ihimizer/img516/2941/cimg1246pl5.th.jpg)
![Shaganova pila Atsclassicwn7.th](https://2img.net/r/ihimizer/img516/9826/atsclassicwn7.th.jpg)
![Shaganova pila Cimg1283hc0.th](https://2img.net/r/ihimizer/img120/1902/cimg1283hc0.th.jpg)
![Shaganova pila Cimg1284qp1.th](https://2img.net/r/ihimizer/img504/3789/cimg1284qp1.th.jpg)
![Shaganova pila Dscf0003wh3.th](https://2img.net/r/ihimizer/img66/549/dscf0003wh3.th.jpg)
![Shaganova pila Dscf0008jj7.th](https://2img.net/r/ihimizer/img182/1306/dscf0008jj7.th.jpg)
Shagan- Član
- Broj komentara : 16
Lokacija : Popovača/Zg
Registration date : 27.04.2009
Re: Shaganova pila
Sve pohvale za cofija, baš je po mom guštu, ništa previše kiča a super izgleda! Ove ATS felge su mu dale malo ozbiljniji izgled. Koliko vidim imaš motor 850. Samo ga čuvaj i pazi isto ka do sada. Pozdrav ![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif)
Re: Shaganova pila
fico ti je bombonćić svaka cast
Re: Shaganova pila
Konzola je od kadeta ko i sicevi a felge su ATS classic 6x13 4x100 gume klasika 165/65.
Shagan- Član
Re: Shaganova pila
Dobar izbor ,ja idem sa felgama BMW 13col ,Et 18 : dim ,guma 165 -65-13 ,ali sjedala ću od Peugeota 205 zato što se samo naslon blago prebaci naprjed inače Peugeot 205 GTI . Dali planiraš šalt tablu još malo obogatiti ili ostaviti tako ??
Re: Shaganova pila
S tim felgama teško da ces moć smotat puni ajnšlag. Neznam dali si primjetio al stavljen je turnceler i tabla ce bit nanovo tapecirana pa bi unutrašnjost trebala poprimit neki malo luksuzniji look.
Shagan- Član
Re: Shaganova pila
Kolega,kao sto vec rekoh u predstavljanju tvom,tvog ficu dobro znam sa slika od prije i imam ih sve spremljene,tako da mi je poznat tvoj rad oko fice...Koliko sam primjetio,limarija ti je odlicna bila kad si ga kupio...Pozdrav
Re: Shaganova pila
Shagan je napisao/la:S tim felgama teško da ces moć smotat puni ajnšlag. Neznam dali si primjetio al stavljen je turnceler i tabla ce bit nanovo tapecirana pa bi unutrašnjost trebala poprimit neki malo luksuzniji look.
Ićiće felge zato što su više van već je isprobano .Da dobra odluka da malo još obogatiš tablu i to će dati dodatne čari ,moja podrška 101% .
Re: Shaganova pila
Bravo, Shagan, očekujemo te i na Osnivačkoj skupštini 23 5. !?
ljubas- Počasni član
- Broj komentara : 592
Re: Shaganova pila
prelijep fićo... sviđa mi se ova boja i ove felgice na njemu... ![Very Happy](https://2img.net/i/fa/i/smiles/icon_biggrin.png)
Jelena- ČLANICA MISS
- Broj komentara : 43
Lokacija : Rijeka-Vežica
Re: Shaganova pila
Evo da dignem malo temu iz groba...
Stigao je nardi je da sam izgubio pola dana na pripasivanje glave ali vrijedilo je... i da još vam dugujem slike komplet unutrašnjosti bit ce ovaj vikend ^^
![Shaganova pila Dgtqth640x480.th](https://2img.net/r/ihimizer/img686/3352/dgtqth640x480.th.jpg)
Shagan- Član
Re: Shaganova pila
Volan je aftermarket Nardijev... naravno da nisam kupio novog pošto je novi oko 300 dolara ^^
Shagan- Član
Re: Shaganova pila
dobar volan i ja volim drvene,imam 3 kom,cekaju montažu,pozdrav!
zok fićo- Aktivni Član
- Broj komentara : 479
Re: Shaganova pila
Lepo Lukica, spremaš ga ti...
Re: Shaganova pila
odlican ti je volan
Re: Shaganova pila
Hvala na pohvalama očekujte slike kroz dan dva najviše.
Shagan- Član
Re: Shaganova pila
Krasan fićo općenito, inače nisam ljubitelj drvenih volana u fići, al ovaj mi se sviđa! ![cheers](https://2img.net/i/fa/i/smiles/icon_cheers.png)
Re: Shaganova pila
Evo obečanih slika mislim da je sve rečeno... Slobodno pitajte.
* ![Shaganova pila 2heilxs.th](https://2img.net/r/ihimizer/img136/2908/2heilxs.th.jpg)
* ![Shaganova pila 1dy6td.th](https://2img.net/r/ihimizer/img260/4949/1dy6td.th.jpg)
![Shaganova pila Vmty1c.th](https://2img.net/r/ihimizer/img32/5296/vmty1c.th.jpg)
![Shaganova pila Mcs0u9.th](https://2img.net/r/ihimizer/img98/810/mcs0u9.th.jpg)
![Shaganova pila 290y07b.th](https://2img.net/r/ihimizer/img267/4207/290y07b.th.jpg)
![Shaganova pila 2ebe4hg.th](https://2img.net/r/ihimizer/img130/579/2ebe4hg.th.jpg)
![Shaganova pila 1ftuv4.th](https://2img.net/r/ihimizer/img140/205/1ftuv4.th.jpg)
Zadnja promjena: Filip; 29/3/2010, 12:30; ukupno mijenjano 1 put. (Reason for editing : Velike slike)
Shagan- Član
Re: Shaganova pila
Odlično shagane.... Kad gledam te slike odmah se sjetim udobnosti.. Sjedala i volan
Jel ima još planova??
![king](https://2img.net/i/fa/i/smiles/icon_king.png)
jasmin.ck- Aktivni Član
- Broj komentara : 628
Re: Shaganova pila
Odlično izgleda, makar kad se i sjetim sam odlično je izgledao.
Vidim nisi riješio još onu rupicu koja ti je ostala malo izbočena ispod tapecirunga ispred suvozača, hehe.
Jel si registriro? Spremaš za ozalj?
