Tehnički podatci - Abarth 750
3 posters
Motor Bore: Strike: engine capacity: Maximum power: | 61 mm 64 mm 747 cc 41,5 hp bij 5500 rpm | |
Distribution Inlet: Exhaust: Valve clearance: | Open 30º for T.D.C. Close 70º to B.D.C. Open 70º voor B.D.C. Close 30º to T.D.C. 0,20 mm | |
Carburetion Venturi: Main jet: Idle jet: Pump jet: Air jet: Emulsion jet: | Weber 32 imp 22 mm 1,20 mm 0,50 mm 0,50 mm 1,80 mm F4 | Weber 32 DRNP2 22 mm 1,30 mm 0,50 mm 0,45 mm 1,80 mm F1 |
Performance With one person: Top speed: Maximum rpm: | 1 km in 40 2/10 sec 130 km/uur 5900 rpm | |
Capacity sump | 4 ltr Castrol XL 30/40 | |
Ignition Fixed pre-ignition: Automatic pre-ignition: Claerance points: Sparkplugs: Electrode distance: | 8º 30º 0,45 mm Marelli 240 0,60 mm | |
Clutch Springs Abarth normal: Abarth competition: | R = 45/40 kg R = 60/63 kg | |
Gearbox 1st 2nd 3rd 4th differential: | 13/44 3,384 : 1 18/37 2,055 : 1 24/32 1,333 : 1 29/26 0,896 : 1 8/39 | On request: 2nd 20/35 3rd 25/30 4th 27/28 30/25 differential 8/43 - 8/41 - 8/40 - 9/41 - 9/39 |
Wheels and Tires Rim size: Tire: Tire pressure: | 3½ x 12" 5,20 x 12" front 1,2 atm rear 1,5 atm | |
Special versions 750 Grand Touring Mille Miglia Compression ratio 9.8: 1, Max.vermogen 44 hp at 6000 rpm, crankshaft and connecting rods, etc. polished. | ||
750 Grand Touring Mille Miglia (Special) Compression ratio 9.8: 1, max power 46 hp at 6000 rpm, flaps, thicker head bolts now instead of 8 mm 10 mm thick. All parts are polished. | ||
750 Grand Touring Mille Miglia (Especially for short circuits) Same as above except that the compression ratio increased. Max. power 47 hp at 6200 rpm |
Re: Tehnički podatci - Abarth 750
Netko je negdje spomenuo da ovaj opisani model abartha 750 derivazione ima bregastu kao nas z750special, zanima me, sta se događa da na z750special ventile nastimam kao ovaj abarth na 0,20? Koje su prednosti, a koje mane? Lp ![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif)
Tunja- Aktivni Član
- Broj komentara : 112
Jel moze itko pomoći?
Tunja- Aktivni Član
Ima slike nema zvuka, da znam pomogao bi ![Neutral](https://2img.net/i/fa/i/smiles/icon_neutral.gif)
Optimista- Aktivni Član
- Broj komentara : 115
Lokacija : Novi Vinodolski
Ili ovo, da prokomentiramo, pretpaljenje na 8stupnjeva, kolko je na fići kad se nastela propisno? I pretpostavaljam da je ovo zazor na platinama 0,45mm..uglavnom, sta bi se događalo na fići s tim postavkama?
Tunja- Aktivni Član
» Tehnički podatci - Abarth 850 TC
» Tehnički podatci - Abarth 850 TC Corsa
» Tehnički podatci - Abarth 850 TCR Corsa
» Tehnički podatci - Abarth 1000 TC (Gruppo II)
» abarth homologacija
